Acer Iconia B1-720 Battery Replacement
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: step 1, image 1 of 3 Acer Iconia B1-720 Battery Replacement, Rear Case: step 1, image 2 of 3 Acer Iconia B1-720 Battery Replacement, Rear Case: step 1, image 3 of 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: step 2, image 1 of 3 Acer Iconia B1-720 Battery Replacement: step 2, image 2 of 3 Acer Iconia B1-720 Battery Replacement: step 2, image 3 of 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: step 3, image 1 of 2 Acer Iconia B1-720 Battery Replacement: step 3, image 2 of 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: step 4, image 1 of 2 Acer Iconia B1-720 Battery Replacement, Battery: step 4, image 2 of 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: step 6, image 1 of 3 Acer Iconia B1-720 Battery Replacement: step 6, image 2 of 3 Acer Iconia B1-720 Battery Replacement: step 6, image 3 of 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
5 other people completed this guide.
Kervis Boston
479 Reputation
3 Guides authored
2 Comments
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - Reply
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 2,900
