Acer Iconia B1-720 Front Facing Camera Replacement
  1. Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: step 1, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: step 1, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: step 1, image 3 of 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Front Facing Camera Replacement: step 2, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 2, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 2, image 3 of 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Front Facing Camera Replacement: step 3, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 3, image 2 of 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: step 4, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: step 4, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: step 4, image 3 of 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Front Facing Camera Replacement: step 5, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 5, image 2 of 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Front Facing Camera Replacement: step 6, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 6, image 2 of 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  7. Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: step 7, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: step 7, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: step 7, image 3 of 3
    • Remove the yellow tape covering both ribbons in the two photos shown.
  8. Acer Iconia B1-720 Front Facing Camera Replacement: step 8, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  9. Acer Iconia B1-720 Front Facing Camera Replacement: step 9, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 9, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 9, image 3 of 3
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  10. Acer Iconia B1-720 Front Facing Camera Replacement: step 10, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 10, image 2 of 2
    • Use tweezers to gently remove black ribbon from locking mechanism.
  11. Acer Iconia B1-720 Front Facing Camera Replacement: step 11, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 11, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 11, image 3 of 3
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
  12. Acer Iconia B1-720 Front Facing Camera Replacement, Front Facing Camera: step 12, image 1 of 1
    • Flip the motherboard over so that you see the camera, micro usb port, and headphone jack.
    • The object marked in red is the camera.
  13. Acer Iconia B1-720 Front Facing Camera Replacement: step 13, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 13, image 2 of 2
    • Grab and gently lift the camera up from the motherboard until it becomes disconnected.
Kervis Boston
479 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 411
