Acer Iconia B1-720 Rear Case Replacement
  1. Acer Iconia B1-720 Rear Case Replacement, Rear Case: step 1, image 1 of 3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: step 1, image 2 of 3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: step 1, image 3 of 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Rear Case Replacement: step 2, image 1 of 3 Acer Iconia B1-720 Rear Case Replacement: step 2, image 2 of 3 Acer Iconia B1-720 Rear Case Replacement: step 2, image 3 of 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Rear Case Replacement: step 3, image 1 of 2 Acer Iconia B1-720 Rear Case Replacement: step 3, image 2 of 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
2 other people completed this guide.
Phillip Keavey
319 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 853
