Acer Iconia B1-A71 LCD Display Replacement
Video Overview
  1. Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: step 1, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: step 1, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: step 1, image 3 of 3
    • Switch-off the tablet.
    • If you can't switch it off, use the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 LCD Display Replacement: step 2, image 1 of 2 Acer Iconia B1-A71 LCD Display Replacement: step 2, image 2 of 2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 LCD Display Replacement: step 3, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 3, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 3, image 3 of 3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 LCD Display Replacement: step 4, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 4, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 4, image 3 of 3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 LCD Display Replacement: step 5, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 5, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 5, image 3 of 3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
6 other people completed this guide.
ZFix
191,906 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 11,064
