Acer Iconia One 7 Speaker Replacement
  1. Acer Iconia One 7 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult; use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Speaker Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Speaker Replacement: step 3, image 1 of 1
    • Turn the tablet over to locate the speaker.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
    • The speaker is on the bottom of the inside.
  4. Acer Iconia One 7 Speaker Replacement: step 4, image 1 of 2 Acer Iconia One 7 Speaker Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Peel back tape.
    • Using tweezers, detach connection from motherboard.
  5. Acer Iconia One 7 Speaker Replacement: step 5, image 1 of 3 Acer Iconia One 7 Speaker Replacement: step 5, image 2 of 3 Acer Iconia One 7 Speaker Replacement: step 5, image 3 of 3
    • Unscrew screws with a JIS screwdriver with a #00 screw bit.
    • Dislodge the speaker unit.
    • Take care not to displace any other bits in the device.
Michael
519 Reputation
4 Guides authored
USF Tampa, Team 8-5, Eyestone Fall 2015 Member of USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 423
