Acer Iconia One 8 Battery Replacement
  1. Acer Iconia One 8 Battery Replacement, Battery: step 1, image 1 of 2 Acer Iconia One 8 Battery Replacement, Battery: step 1, image 2 of 2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: step 2, image 1 of 1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: step 3, image 1 of 1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: step 4, image 1 of 1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,880
