Acer Iconia One 8 Motherboard Replacement
  1. Acer Iconia One 8 Motherboard Replacement, Screen: step 1, image 1 of 2 Acer Iconia One 8 Motherboard Replacement, Screen: step 1, image 2 of 2
    • Begin by opening the back panel.
    • Wedge a plastic opening tool in between the front and back shell and gently separate.
  2. Acer Iconia One 8 Motherboard Replacement: step 2, image 1 of 3 Acer Iconia One 8 Motherboard Replacement: step 2, image 2 of 3 Acer Iconia One 8 Motherboard Replacement: step 2, image 3 of 3
    • Peel back all pieces of tape indicated in picture.
    • There are three pieces of tape total (2 Black and 1 Silver).
  3. Acer Iconia One 8 Motherboard Replacement: step 3, image 1 of 3 Acer Iconia One 8 Motherboard Replacement: step 3, image 2 of 3 Acer Iconia One 8 Motherboard Replacement: step 3, image 3 of 3
    • Disconnect all cables from the device.
    • There should be 5 total.
  4. Acer Iconia One 8 Motherboard Replacement: step 4, image 1 of 3 Acer Iconia One 8 Motherboard Replacement: step 4, image 2 of 3 Acer Iconia One 8 Motherboard Replacement: step 4, image 3 of 3
    • Remove the nine 3mm screws using the Phillips #000 screwdriver.
  5. Acer Iconia One 8 Motherboard Replacement: step 5, image 1 of 1
    • Remove and separate the back plating (top) from the glass screen (bottom).
  6. Acer Iconia One 8 Motherboard Replacement, Motherboard: step 6, image 1 of 2 Acer Iconia One 8 Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Disconnect the metal tabs connecting the battery to the motherboard frame.
  7. Acer Iconia One 8 Motherboard Replacement: step 7, image 1 of 2 Acer Iconia One 8 Motherboard Replacement: step 7, image 2 of 2
    • Disconnect the cable for the back camera.
  8. Acer Iconia One 8 Motherboard Replacement: step 8, image 1 of 1
    • Flip the metal plating to reveal the front camera.
  9. Acer Iconia One 8 Motherboard Replacement: step 9, image 1 of 2 Acer Iconia One 8 Motherboard Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to carefully remove the front camera from the adhesive on the motherboard.
  10. Acer Iconia One 8 Motherboard Replacement: step 10, image 1 of 3 Acer Iconia One 8 Motherboard Replacement: step 10, image 2 of 3 Acer Iconia One 8 Motherboard Replacement: step 10, image 3 of 3
    • Flip the device back over.
    • Remove the motherboard from the metallic frame by feeding the back camera and front camera cable through the port.
    • Remove the front camera from the device.
Dustin Newland
343 Reputation
3 Guides authored
IUPUI, Team S1-G2, Stella Fall 2019 Member of IUPUI, Team S1-G2, Stella Fall 2019
IUPUI-STELLA-F19S1G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 255
