Acer Iconia Tab 8 A1-840 Front Camera Replacement
  1. Acer Iconia Tab 8 A1-840 Front Camera Replacement, Back Panel: step 1, image 1 of 1
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Front Camera Replacement: step 2, image 1 of 1
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Front Camera Replacement: step 3, image 1 of 1
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Front Camera Replacement, Front Camera: step 4, image 1 of 1
    • Use the spudger to lift the the black flap.
  5. Acer Iconia Tab 8 A1-840 Front Camera Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use the ESD safe precision tweezers to pull the connector out and carefully remove the camera.
Claire Posadas
396 Reputation
3 Guides authored
UW Tacoma, Team 1-1, Rose Fall 2016 Member of UW Tacoma, Team 1-1, Rose Fall 2016
UWT-ROSE-F16S1G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 413
