Acer Iconia Tab 8 A1-860 Speaker Replacement
  1. Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: step 1, image 1 of 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: step 1, image 2 of 2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Speaker Replacement: step 2, image 1 of 1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Speaker Replacement, Battery: step 3, image 1 of 1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Speaker Replacement: step 4, image 1 of 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: step 4, image 2 of 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: step 4, image 3 of 3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: step 5, image 1 of 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: step 5, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  6. Acer Iconia Tab 8 A1-860 Speaker Replacement: step 6, image 1 of 2 Acer Iconia Tab 8 A1-860 Speaker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to gently lift off the connector and wires attached to the speakers.
    • Remove the speakers from the device.
2 other people completed this guide.
Michael Buchanan
361 Reputation
2 Guides authored
IUPUI, Team S2-G3, Harley Spring 2019 Member of IUPUI, Team S2-G3, Harley Spring 2019
IUPUI-HARLEY-S19S2G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 149
