Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement
Daksh Malhotra
Daksh Malhotra and 5 other contributors
Last updated on May 23, 2024
10 - 15 minutes
Easy
Introduction
Go to step 1
The USB-A/Micro-USB Port enhances the connectivity of the tablet to other portable devices. Follow this guide to replace the USB-A/Micro-USB Port.
Tools
Show more…
  1. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, Back Cover: step 1, image 1 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, Back Cover: step 1, image 2 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, Back Cover: step 1, image 3 of 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 2, image 1 of 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, USB-A/Micro-USB Port: step 3, image 1 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, USB-A/Micro-USB Port: step 3, image 2 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement, USB-A/Micro-USB Port: step 3, image 3 of 3
    Tool used on this step:
    $3.99
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 4, image 1 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 4, image 2 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to flip up the locking mechanism for the flat, white ribbon cable connecting to the USB ports' board.
    • Remove the flat, white ribbon cable.
  5. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 5, image 1 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 5, image 2 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 5, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 4.0 mm Philips screws attaching the metal plate, USB board, and device.
  6. Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 6, image 1 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 6, image 2 of 3 Acer Iconia Tab A501 USB-A/Micro-USB Port Replacement: step 6, image 3 of 3
    Halberd Spudger
    $2.99
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 337
