Acer Iconia W3-810 Speaker Replacement
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: step 4, image 1 of 1
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: step 5, image 1 of 1
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: step 6, image 1 of 1
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: step 7, image 1 of 1
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: step 8, image 1 of 1
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: step 9, image 1 of 1
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: step 10, image 1 of 1
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: step 11, image 1 of 1
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: step 12, image 1 of 1
    • Remove the speakers from the device.
Griffin Hocker
394 Reputation
3 Guides authored
USF Tampa, Team 18-4, Blackwell Fall 2016 Member of USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 8
All Time: 436
