Acer Iconia W510 Dock Battery Replacement
  1. Acer Iconia W510 Dock Battery Replacement, Bottom Cover: step 1, image 1 of 1
    • Remove the two 6.6mmT6 Torx screws near the hinge.
    • Remove the four 3.6mm T6 Torx screws on either side.
  2. Acer Iconia W510 Dock Battery Replacement: step 2, image 1 of 3 Acer Iconia W510 Dock Battery Replacement: step 2, image 2 of 3 Acer Iconia W510 Dock Battery Replacement: step 2, image 3 of 3
    • Using an Xacto knife, peel the rubber strip back far enough on either end to expose the two screws.
    • Remove the two 4.5mm Phillips screws.
  3. Acer Iconia W510 Dock Battery Replacement: step 3, image 1 of 3 Acer Iconia W510 Dock Battery Replacement: step 3, image 2 of 3 Acer Iconia W510 Dock Battery Replacement: step 3, image 3 of 3
    • Unclip the rear cover.
  4. Acer Iconia W510 Dock Battery Replacement: step 4, image 1 of 3 Acer Iconia W510 Dock Battery Replacement: step 4, image 2 of 3 Acer Iconia W510 Dock Battery Replacement: step 4, image 3 of 3
    • Remove the bottom cover.
  5. Acer Iconia W510 Dock Battery Replacement, Unplug the Battery: step 5, image 1 of 2 Acer Iconia W510 Dock Battery Replacement, Unplug the Battery: step 5, image 2 of 2
    • Using the two tabs on either side of the connector, unplug the battery.
  6. Acer Iconia W510 Dock Battery Replacement, Remove the Battery: step 6, image 1 of 1
    • Two strips of adhesive on either side hold the battery in place.
  7. Acer Iconia W510 Dock Battery Replacement: step 7, image 1 of 3 Acer Iconia W510 Dock Battery Replacement: step 7, image 2 of 3 Acer Iconia W510 Dock Battery Replacement: step 7, image 3 of 3
    • Use a flexible piece of plastic to slice the strip of adhesive on one side.
    • Leave the plastic in place when doing the other side.
  8. Acer Iconia W510 Dock Battery Replacement: step 8, image 1 of 3 Acer Iconia W510 Dock Battery Replacement: step 8, image 2 of 3 Acer Iconia W510 Dock Battery Replacement: step 8, image 3 of 3
    • Slice the strip of adhesive on the other side.
  9. Acer Iconia W510 Dock Battery Replacement: step 9, image 1 of 1
    • Lift the battery from the dock.
  10. Acer Iconia W510 Dock Battery Replacement: step 10, image 1 of 1
    • The battery is now free.
Jerry Wheeler
60,179 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
178 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 104
