Acer Nitro 5 AN515-53-52FA Fan Replacement
  1. Acer Nitro 5 AN515-53-52FA Fan Replacement, Fan: step 1, image 1 of 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up
  2. Acer Nitro 5 AN515-53-52FA Fan Replacement: step 2, image 1 of 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: step 2, image 2 of 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Fan Replacement: step 3, image 1 of 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: step 3, image 2 of 2
    • Use a plastic opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
    • Removing the backshell of the laptop will reveal the inside of it.
    • The fan of the laptop is located on the top left of the laptop.
  4. Acer Nitro 5 AN515-53-52FA Fan Replacement: step 4, image 1 of 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: step 4, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the four 9 mm screws securing the fans.
  5. Acer Nitro 5 AN515-53-52FA Fan Replacement: step 5, image 1 of 3 Acer Nitro 5 AN515-53-52FA Fan Replacement: step 5, image 2 of 3 Acer Nitro 5 AN515-53-52FA Fan Replacement: step 5, image 3 of 3
    • Unplug the connectors before taking the fan out.
  6. Acer Nitro 5 AN515-53-52FA Fan Replacement: step 6, image 1 of 2 Acer Nitro 5 AN515-53-52FA Fan Replacement: step 6, image 2 of 2
    • Gently remove the fans from the adhesive strip.
3 other people completed this guide.
Alfredo Prieto
827 Reputation
5 Guides authored
Gateway, Team 1-3, Pee Fall 2022 Member of Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Members
5 Guides authored
One Comment
thank you so much
Muhammet Enes Utku - Reply
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 50
All Time: 896
