Acer Nitro 5 AN515-55 SSD Replacement
  1. Acer Nitro 5 AN515-55 SSD Replacement, SSD: step 1, image 1 of 1
    • Shut down your laptop.
    • Make sure your laptop is completely turned off to prevent damaging other parts.
  2. Acer Nitro 5 AN515-55 SSD Replacement: step 2, image 1 of 3 Acer Nitro 5 AN515-55 SSD Replacement: step 2, image 2 of 3 Acer Nitro 5 AN515-55 SSD Replacement: step 2, image 3 of 3
    • Flip the laptop on its back.
    • Remove the eleven 8 mm screws securing the back cover using the Phillips #1 screwdriver.
  3. Acer Nitro 5 AN515-55 SSD Replacement: step 3, image 1 of 2 Acer Nitro 5 AN515-55 SSD Replacement: step 3, image 2 of 2
    • Loosen the back cover using a plastic opening tool.
  4. Acer Nitro 5 AN515-55 SSD Replacement: step 4, image 1 of 2 Acer Nitro 5 AN515-55 SSD Replacement: step 4, image 2 of 2
    • Pull the back cover off and put it in a safe place.
    • A little bit of force is needed to pry open the clips at the corners of the laptop.
  5. Acer Nitro 5 AN515-55 SSD Replacement: step 5, image 1 of 3 Acer Nitro 5 AN515-55 SSD Replacement: step 5, image 2 of 3 Acer Nitro 5 AN515-55 SSD Replacement: step 5, image 3 of 3
    • Remove the 2.6 mm screw that is holding down the SSD with a Phillips #0 screwdriver.
    • Make sure to ground yourself before working on the motherboard to prevent damage.
  6. Acer Nitro 5 AN515-55 SSD Replacement: step 6, image 1 of 3 Acer Nitro 5 AN515-55 SSD Replacement: step 6, image 2 of 3 Acer Nitro 5 AN515-55 SSD Replacement: step 6, image 3 of 3
    • Gently pull out the damaged SSD.
  7. Acer Nitro 5 AN515-55 SSD Replacement: step 7, image 1 of 2 Acer Nitro 5 AN515-55 SSD Replacement: step 7, image 2 of 2
    • Slide in the new SSD.
    • Screw it in place.
  8. Acer Nitro 5 AN515-55 SSD Replacement: step 8, image 1 of 2 Acer Nitro 5 AN515-55 SSD Replacement: step 8, image 2 of 2
    • Put the back cover on and gently snap the clips back in.
    • Screw the back cover in place.
Follow the guide that comes with your new SSD to make sure your laptop recognizes your new SSD.
5 other people completed this guide.
Solomon Mekuria
271 Reputation
1 Guide authored
One Comment
This model is supposed to have 3 slots 2 for SSD and 1 for HDD, can you please point them out? Just add an extra SDD?
mayumidb - Reply
Past 24 Hours: 6
Past 7 Days: 59
Past 30 Days: 178
All Time: 8,164
