Acer Nitro 5 AN515-55-55M1 Battery Replacement
  1. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Bottom Cover: step 1, image 1 of 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Battery Replacement: step 2, image 1 of 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: step 2, image 2 of 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: step 3, image 1 of 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: step 3, image 2 of 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: step 3, image 3 of 3
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Battery Replacement: step 4, image 1 of 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: step 4, image 2 of 2
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
Congratulations! You have successfully replaced the battery of your Acer Nitro 5 AN515-55-55M1!
2 other people completed this guide.
Samuel Rouillard
681 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 223
All Time: 10,870
