Acer Nitro 5 AN517-51-56YW Battery Replacement
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: step 1, image 1 of 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: step 1, image 2 of 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: step 1, image 3 of 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: step 2, image 1 of 2 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: step 2, image 2 of 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: step 3, image 1 of 2 Acer Nitro 5 AN517-51-56YW Battery Replacement: step 3, image 2 of 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
2 other people completed this guide.
Jacob Elkins
221 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 8
Past 30 Days: 32
All Time: 2,212
