Acer Nitro 5 AN517-51-56YW RAM Replacement
  1. Acer Nitro 5 AN517-51-56YW RAM Replacement, Bottom Cover: step 1, image 1 of 3 Acer Nitro 5 AN517-51-56YW RAM Replacement, Bottom Cover: step 1, image 2 of 3 Acer Nitro 5 AN517-51-56YW RAM Replacement, Bottom Cover: step 1, image 3 of 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW RAM Replacement, RAM: step 2, image 1 of 2 Acer Nitro 5 AN517-51-56YW RAM Replacement, RAM: step 2, image 2 of 2
    • Use your fingers to pry apart the two metal brackets on either side of the RAM.
    • The RAM will pop up.
  3. Acer Nitro 5 AN517-51-56YW RAM Replacement: step 3, image 1 of 1
    • Pull the card straight towards yourself.
Colin Moore
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 35
All Time: 553
