Acer One 10 S1002 145-A Battery Replacement
  1. Acer One 10 S1002 145-A Battery Replacement, Motherboard: step 1, image 1 of 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Battery Replacement: step 2, image 1 of 2 Acer One 10 S1002 145-A Battery Replacement: step 2, image 2 of 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Battery Replacement: step 3, image 1 of 3 Acer One 10 S1002 145-A Battery Replacement: step 3, image 2 of 3 Acer One 10 S1002 145-A Battery Replacement: step 3, image 3 of 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Battery Replacement: step 4, image 1 of 2 Acer One 10 S1002 145-A Battery Replacement: step 4, image 2 of 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Battery Replacement: step 5, image 1 of 3 Acer One 10 S1002 145-A Battery Replacement: step 5, image 2 of 3 Acer One 10 S1002 145-A Battery Replacement: step 5, image 3 of 3
  6. Acer One 10 S1002 145-A Battery Replacement: step 6, image 1 of 2 Acer One 10 S1002 145-A Battery Replacement: step 6, image 2 of 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Battery Replacement: step 7, image 1 of 3 Acer One 10 S1002 145-A Battery Replacement: step 7, image 2 of 3 Acer One 10 S1002 145-A Battery Replacement: step 7, image 3 of 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Battery Replacement: step 8, image 1 of 1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Battery Replacement, Battery: step 9, image 1 of 3 Acer One 10 S1002 145-A Battery Replacement, Battery: step 9, image 2 of 3 Acer One 10 S1002 145-A Battery Replacement, Battery: step 9, image 3 of 3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
20 other people completed this guide.
Shannon Griffin
1,372 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Fall 2016 Member of USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Members
5 Guides authored
2 Comments
Thankyou for this information. I am replacing a battery on my own, and your tutorial is extremely clear and helpful.
shop_arod - Reply
I want a ..
Motherboard
4D Guru Channel - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 75
All Time: 18,825
