Acer One 10 S1003-19GY Motherboard Replacement
  1. Acer One 10 S1003-19GY Motherboard Replacement, Motherboard: step 1, image 1 of 2 Acer One 10 S1003-19GY Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Motherboard Replacement: step 2, image 1 of 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Motherboard Replacement: step 3, image 1 of 3 Acer One 10 S1003-19GY Motherboard Replacement: step 3, image 2 of 3 Acer One 10 S1003-19GY Motherboard Replacement: step 3, image 3 of 3
    • Open latch and safely remove the ribbon.
  4. Acer One 10 S1003-19GY Motherboard Replacement: step 4, image 1 of 3 Acer One 10 S1003-19GY Motherboard Replacement: step 4, image 2 of 3 Acer One 10 S1003-19GY Motherboard Replacement: step 4, image 3 of 3
    • Use Phillips #000 screwdriver to remove seven 3mm Phillips screws from the motherboard.
  5. Acer One 10 S1003-19GY Motherboard Replacement: step 5, image 1 of 1
    • Safely remove the motherboard.
Nuha Alshaibani
241 Reputation
2 Guides authored
IUPUI, Team S1-G2, Harley Summer 2019 Member of IUPUI, Team S1-G2, Harley Summer 2019
IUPUI-HARLEY-SU19S1G2
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 972
