Acer One 10 S1003-19GY Rear/Front Camera Replacement
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: step 1, image 1 of 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: step 1, image 2 of 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 2, image 1 of 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: step 3, image 1 of 1
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 4, image 1 of 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 4, image 2 of 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 4, image 3 of 3
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 5, image 1 of 1
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 6, image 1 of 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement: step 6, image 2 of 2
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 373
