Acer One 10 S1003-19GY WiFi Antenna Replacement
  1. Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: step 1, image 1 of 2 Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: step 1, image 2 of 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY WiFi Antenna Replacement: step 2, image 1 of 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: step 3, image 1 of 3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: step 3, image 2 of 3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: step 3, image 3 of 3
    • Disconnect the black ribbon connection attached to the motherboard.
    • Remove the chip fully by pulling the plastic tab on the left out.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 707
