Introduction
If the display of the Acer Predator 17 G9-791 is completely black or dim. The display might be disabled. To fix this, hold the “Fn” key located near the bottom left of the keyboard and press “F5.” If the display is disabled, this will re-enable the display.
If this does not fix the issue, repeat the above step once more. Then, hold down the Windows key and press “P” twice. The computer may have been set to “Second screen only,” which will set the computer back to “PC screen only.”
If nothing from above fixes the issue, use this guide to replace the display.
The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
Remove the nine 4.5 mm Phillips #0 screws from the panel.
Remove four 14 mm Phillips #0 screws.
Remove six 7 mm Phillips #0 screws.
Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
Push down on the back of the device to unclip this panel, removing it by pulling it out the back of the device.
