Introduction
If you need to access the inside of your Acer Predator G9 791, use this guide to begin with replacing the service panel.
Before you begin, make sure that the laptop is fully powered down and disconnected from its charger.
The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
Almost done!
