Acer Predator Helios 300 (2020) Battery Replacement
  1. Acer Predator Helios 300 (2020) Battery Replacement, Battery: step 1, image 1 of 2 Acer Predator Helios 300 (2020) Battery Replacement, Battery: step 1, image 2 of 2
    • Turn off the laptop by holding the power button for 7 seconds.
  2. Acer Predator Helios 300 (2020) Battery Replacement: step 2, image 1 of 2 Acer Predator Helios 300 (2020) Battery Replacement: step 2, image 2 of 2
    • Remove the eleven black 7.0 mm screws using a Phillips #00 screwdriver.
  3. Acer Predator Helios 300 (2020) Battery Replacement: step 3, image 1 of 2 Acer Predator Helios 300 (2020) Battery Replacement: step 3, image 2 of 2
    • Put your hands on the silver part of the chassis and pull up until you hear a snap.
    • Lift up the back panel and remove it from the device.
  4. Acer Predator Helios 300 (2020) Battery Replacement: step 4, image 1 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 4, image 2 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 4, image 3 of 3
    • Remove the two 4.0 mm golden screws using the Phillips #00 screwdriver.
  5. Acer Predator Helios 300 (2020) Battery Replacement: step 5, image 1 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 5, image 2 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 5, image 3 of 3
    • Disconnect the battery connector.
  6. Acer Predator Helios 300 (2020) Battery Replacement: step 6, image 1 of 1
    • Remove the battery from the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 other people completed this guide.
Steven Yuen
349 Reputation
1 Guide authored
One Comment
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
Jeff Noble - Reply
Past 24 Hours: 10
Past 7 Days: 41
Past 30 Days: 146
All Time: 14,161
