Acer Spin 3 SP315-51-757C Charger Port Replacement
  1. Acer Spin 3 SP315-51-757C Charger Port Replacement, Back Panel: step 1, image 1 of 2 Acer Spin 3 SP315-51-757C Charger Port Replacement, Back Panel: step 1, image 2 of 2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Charger Port Replacement: step 2, image 1 of 3 Acer Spin 3 SP315-51-757C Charger Port Replacement: step 2, image 2 of 3 Acer Spin 3 SP315-51-757C Charger Port Replacement: step 2, image 3 of 3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Charger Port Replacement: step 3, image 1 of 1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Charger Port Replacement, Charger Port: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • The charger port's inner cable may be covered by a manufacturer sticker, which can be easily removed.
    • Using your nails or tweezers, unplug the charger port cable from the motherboard.
  5. Acer Spin 3 SP315-51-757C Charger Port Replacement: step 5, image 1 of 1
    • Gently lift the charger port out of its slot in the laptop casing.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 3,173
