Introduction
This is a guide instructing how to replace the Acer Spin 3 SP315-51-757C trackpad. Indications that you would need a new trackpad is outdated or corrupt drivers, incorrect touchpad settings, hardware failure, or more.
Using your nails or tweezers, unplug the charger port cable from the motherboard.
Lift the three black tabs to release the cable connectors.
After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
Using a Phillips #0 screwdriver, remove the three screws that hold the fan on top of the motherboard.
