Acer Spin 5 N17W2 Battery Replacement
  1. Acer Spin 5 N17W2 Battery Replacement, Battery: step 1, image 1 of 2 Acer Spin 5 N17W2 Battery Replacement, Battery: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Battery Replacement: step 2, image 1 of 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Battery Replacement: step 3, image 1 of 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Battery Replacement: step 4, image 1 of 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Battery Replacement: step 5, image 1 of 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Battery Replacement: step 6, image 1 of 1
    • Remove the battery from the device.
4 other people completed this guide.
One Comment
Do you guys sell this exact battery replacement?
Sara B - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 103
All Time: 10,248
