Acer Spin 5 N17W2 Cooling Fan Replacement
  1. Acer Spin 5 N17W2 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 2 Acer Spin 5 N17W2 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 2
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Cooling Fan Replacement: step 2, image 1 of 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Cooling Fan Replacement: step 3, image 1 of 1
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Cooling Fan Replacement: step 4, image 1 of 2 Acer Spin 5 N17W2 Cooling Fan Replacement: step 4, image 2 of 2
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 873
