Acer Spin 5 N17W2 Motherboard Replacement
  1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: step 1, image 1 of 2 Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: step 1, image 2 of 2
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Motherboard Replacement: step 2, image 1 of 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Motherboard Replacement: step 3, image 1 of 1
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Motherboard Replacement: step 4, image 1 of 2 Acer Spin 5 N17W2 Motherboard Replacement: step 4, image 2 of 2
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
  5. Acer Spin 5 N17W2 Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove four 5 mm screws using the Phillips #1 screwdriver.
  6. Acer Spin 5 N17W2 Motherboard Replacement: step 6, image 1 of 1
    • Take off the black heat sink (be careful of the grey thermal grease).
  7. Acer Spin 5 N17W2 Motherboard Replacement: step 7, image 1 of 3 Acer Spin 5 N17W2 Motherboard Replacement: step 7, image 2 of 3 Acer Spin 5 N17W2 Motherboard Replacement: step 7, image 3 of 3
    • Remove all peripherals connecting to the motherboard.
    • Remove the second chip.
    • Remove the wireless LAN chip.
  8. Acer Spin 5 N17W2 Motherboard Replacement: step 8, image 1 of 1
    • Disconnect the three connection wires.
  9. Acer Spin 5 N17W2 Motherboard Replacement: step 9, image 1 of 2 Acer Spin 5 N17W2 Motherboard Replacement: step 9, image 2 of 2
    • Take off the connecting port with black tape.
    • Take off the last port with purple tape.
  10. Acer Spin 5 N17W2 Motherboard Replacement: step 10, image 1 of 1
    • Remove the motherboard from the device.
2 Comments
I need the motherboard where I can buy it..
john fredy mendoza torres - Reply
I need the motherboard where I can buy it please...
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,443
