Acer Spin 5 N17W2 SSD Replacement
  1. Acer Spin 5 N17W2 SSD Replacement, Battery: step 1, image 1 of 2 Acer Spin 5 N17W2 SSD Replacement, Battery: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 SSD Replacement: step 2, image 1 of 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 SSD Replacement: step 3, image 1 of 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 SSD Replacement: step 4, image 1 of 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 SSD Replacement: step 5, image 1 of 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 SSD Replacement: step 6, image 1 of 1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 SSD Replacement, SSD: step 7, image 1 of 1
    • Disconnect the SSD from the laptop.
    • At the time of guide creation, the device did not come equipped with the SSD.
2 Comments
That's not the RAM, that's the m.2 SSD slot. The RAM on this laptop is soldered to the mainboard and cannot be replaced/repaired.
Stephen Feger - Reply
Ok, so they changed this guide from a RAM change to an SSD change. Fine. One thing to point out is that the default m.2 drive for this laptop is a SATA based m.2, not a PCIe. Not sure if it can handle a PCIe m.2 drive.
Stephen Feger -
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 1,879
