Acer Spin 5 N17W2 Screen Assembly Replacement
  1. Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 2 Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: step 1, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the six 6mm screws.
    • Use Phillips #1 screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Screen Assembly Replacement: step 2, image 1 of 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Screen Assembly Replacement: step 3, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the three 5mm screws.
    • Use the Phillips #1 screwdriver to remove the three 5mm screws on another side of hinge.
  4. Acer Spin 5 N17W2 Screen Assembly Replacement: step 4, image 1 of 1
    • Disconnect chips from the two end side of hinge.
  5. Acer Spin 5 N17W2 Screen Assembly Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to pry the hinge up.
  6. Acer Spin 5 N17W2 Screen Assembly Replacement: step 6, image 1 of 1
    • Remove the wireless LAN chip from the motherboard.
  7. Acer Spin 5 N17W2 Screen Assembly Replacement: step 7, image 1 of 1
    • Detach the sensors on each side of the hinge from the motherboard.
  8. Acer Spin 5 N17W2 Screen Assembly Replacement: step 8, image 1 of 1
    • Detach the screen assembly from the device.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 2,544
