Acer Spin 5 N17W2 Trackpad Replacement
  1. Acer Spin 5 N17W2 Trackpad Replacement, Battery: step 1, image 1 of 2 Acer Spin 5 N17W2 Trackpad Replacement, Battery: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Trackpad Replacement: step 2, image 1 of 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Trackpad Replacement: step 3, image 1 of 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Trackpad Replacement: step 4, image 1 of 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Trackpad Replacement: step 5, image 1 of 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Trackpad Replacement: step 6, image 1 of 1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Trackpad Replacement, Trackpad: step 7, image 1 of 1
    • Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
  8. Acer Spin 5 N17W2 Trackpad Replacement: step 8, image 1 of 1
    • Remove ribbon cables connected to the middle of the mouse pad.
    • Remove the adhesive tape from the left side of the mouse pad.
  9. Acer Spin 5 N17W2 Trackpad Replacement: step 9, image 1 of 1
    • Using the phillips #1 screwdriver, remove the 4 screws securing the mouse pad.
  10. Acer Spin 5 N17W2 Trackpad Replacement: step 10, image 1 of 1
    • Using your thumbs, push the mouse pad from the inside of the computer towards ur self and slide the mousepad out of the computer.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 749
