Acer Spin 5 SP513-51-57TP Cooling Fan Replacement
  1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 2, image 1 of 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 3, image 1 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 3, image 2 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 4, image 1 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 4, image 2 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 4, image 3 of 3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 5, image 1 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 5, image 2 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 5, image 3 of 3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: step 6, image 1 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: step 6, image 2 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: step 6, image 3 of 3
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  7. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 7, image 1 of 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 7, image 2 of 2
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  8. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 8, image 1 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 8, image 2 of 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: step 8, image 3 of 3
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
Anthony Vansell
872 Reputation
5 Guides authored
Hufflepuff Member of Hufflepuff
Local Repair Groups
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,310
