Acer Spin 5 SP515-51GN-807G Touchpad Replacement
  1. Acer Spin 5 SP515-51GN-807G Touchpad Replacement, Back Cover: step 1, image 1 of 1
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 2, image 1 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 2, image 2 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 3, image 1 of 1
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Touchpad Replacement, Battery: step 4, image 1 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement, Battery: step 4, image 2 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 5, image 1 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 5, image 2 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 5, image 3 of 3
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 6, image 1 of 2 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 6, image 2 of 2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 7, image 1 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 7, image 2 of 3 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 7, image 3 of 3
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 8, image 1 of 2 Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 8, image 2 of 2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  9. Acer Spin 5 SP515-51GN-807G Touchpad Replacement, Touchpad: step 9, image 1 of 1
    • Unplug the 2 ribbon cables connecting the trackpad to the motherboard by flipping up the locking tabs of the ZIF connectors and pulling out the cables.
  10. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 10, image 1 of 1
    • Remove the three 2.2 mm screws holding the trackpad in place with a Phillips #00 screwdriver.
  11. Acer Spin 5 SP515-51GN-807G Touchpad Replacement: step 11, image 1 of 1
    • Lift the lid of the laptop and push the trackpad out from the inside.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 351
