Acer Swift 3 2022 Fan Replacement
  1. Acer Swift 3 2022 Fan Replacement, Bottom Cover: step 1, image 1 of 1
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
  2. Acer Swift 3 2022 Fan Replacement: step 2, image 1 of 2 Acer Swift 3 2022 Fan Replacement: step 2, image 2 of 2
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
  3. Acer Swift 3 2022 Fan Replacement: step 3, image 1 of 1
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
  4. Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: step 4, image 1 of 3 Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: step 4, image 2 of 3 Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: step 4, image 3 of 3
    • Peel back the strip of black tape.
  5. Acer Swift 3 2022 Fan Replacement: step 5, image 1 of 2 Acer Swift 3 2022 Fan Replacement: step 5, image 2 of 2
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
  6. Acer Swift 3 2022 Fan Replacement, Fan: step 6, image 1 of 2 Acer Swift 3 2022 Fan Replacement, Fan: step 6, image 2 of 2
    • Remove the two 4.5 mm screws from the fan using a Phillips #00 screwdriver.
  7. Acer Swift 3 2022 Fan Replacement: step 7, image 1 of 2 Acer Swift 3 2022 Fan Replacement: step 7, image 2 of 2
    • Lift the metal clip using the iFixit opening tool to release the wire.
  8. Acer Swift 3 2022 Fan Replacement: step 8, image 1 of 3 Acer Swift 3 2022 Fan Replacement: step 8, image 2 of 3 Acer Swift 3 2022 Fan Replacement: step 8, image 3 of 3
    • Unplug the wires by pulling gently on the white plastic.
  9. Acer Swift 3 2022 Fan Replacement: step 9, image 1 of 1
    • Remove fan.
Anna Miller
855 Reputation
6 Guides authored
One Comment
Correction. The fan should face the other way around - with the vent into the radiators of the heatsink. If the fan is placed incorrectly, overheating will occur.
Yehor - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 45
All Time: 754
