Acer Swift X N20C12 Battery Replacement
  1. Acer Swift X N20C12 Battery Replacement, Lower Case: step 1, image 1 of 1
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Battery Replacement: step 2, image 1 of 1
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Battery Replacement, Battery: step 3, image 1 of 1
    • Grasp the battery connector and pull it directly out of its socket.
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws that secure the battery.
  4. Acer Swift X N20C12 Battery Replacement: step 4, image 1 of 1
    • Lift the battery up and out of the chassis.
Abrar
472 Reputation
5 Guides authored
Gateway, Team 1-2, Pee Fall 2023 Member of Gateway, Team 1-2, Pee Fall 2023
GCC-PEE-F23S1G2
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 79
All Time: 918
