Acer Travelmate 220 Disc Drive Replacement
  1. Acer Travelmate 220 Disc Drive Replacement, Disc Drive: step 1, image 1 of 1
    • Flip your computer over so the bottom case is facing you.
  2. Acer Travelmate 220 Disc Drive Replacement: step 2, image 1 of 1
    • Locate the sliding unlock button near the AC power input.
  3. Acer Travelmate 220 Disc Drive Replacement: step 3, image 1 of 1
    • Slide the button in the direction of unlock and hold.
  4. Acer Travelmate 220 Disc Drive Replacement: step 4, image 1 of 1
    • Gently pull the disk drive out.
  5. Acer Travelmate 220 Disc Drive Replacement: step 5, image 1 of 3 Acer Travelmate 220 Disc Drive Replacement: step 5, image 2 of 3 Acer Travelmate 220 Disc Drive Replacement: step 5, image 3 of 3
    • Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
  6. Acer Travelmate 220 Disc Drive Replacement: step 6, image 1 of 2 Acer Travelmate 220 Disc Drive Replacement: step 6, image 2 of 2
    • Remove the black plastic that covers the metal.
  7. Acer Travelmate 220 Disc Drive Replacement: step 7, image 1 of 1
    • Locate the green chip on the back of the drive.
  8. Acer Travelmate 220 Disc Drive Replacement: step 8, image 1 of 2 Acer Travelmate 220 Disc Drive Replacement: step 8, image 2 of 2
    • Remove the two screws securing the green chip.
  9. Acer Travelmate 220 Disc Drive Replacement: step 9, image 1 of 1
    • Firmly pull off the green chip.
  10. Acer Travelmate 220 Disc Drive Replacement: step 10, image 1 of 1
    • Insert the green chip in the new disk drive.
Justin
62 Reputation
1 Guide authored
UW Stout, Team 5-5, Zhou Fall 2011 Member of UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 4,757
