Acer X191 monitor Display Assembly Replacement
  1. Acer X191 monitor Display Assembly Replacement, Stand: step 1, image 1 of 2 Acer X191 monitor Display Assembly Replacement, Stand: step 1, image 2 of 2
    • Lay the monitor on a flat surface, facedown.
    • Use a #1 Phillips screwdriver to remove the 4x 10.2mm screws securing the stand to the back panel.
    • Remove the stand from the back panel by pulling it up.
  2. Acer X191 monitor Display Assembly Replacement, Back Cover: step 2, image 1 of 1
    • Remove the 2x 9.8mm Phillips #1 screws securing the back cover to the monitor.
  3. Acer X191 monitor Display Assembly Replacement: step 3, image 1 of 2 Acer X191 monitor Display Assembly Replacement: step 3, image 2 of 2
    • Work your way around the monitor, putting the flathead screwdriver into the space between the front and back covers, and prying up.
    • Twisting the screwdriver can help, but you can easily mess up the plastic without getting anything out of it by doing so. Be cautious.
    • Ideally you want to pry at the locations that have the little gaps, which are locking mechanisms.
    • You should hear a poping sound and the back cover should lift a little if you are prying at the right locations.
  4. Acer X191 monitor Display Assembly Replacement: step 4, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 4, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 4, image 3 of 3
    • I've highlighted the locations of the locking mechanisms for the back cover, try prying in these locations for the best results.
    • Right side of the monitor.
    • Top of the monitor.
    • Left side of the monitor.
  5. Acer X191 monitor Display Assembly Replacement: step 5, image 1 of 1
    • On the bottom side, be careful not to pry on the monitor buttons.
    • Bottom of the monitor locking mechanism locations.
  6. Acer X191 monitor Display Assembly Replacement: step 6, image 1 of 2 Acer X191 monitor Display Assembly Replacement: step 6, image 2 of 2
    • The monitor back cover will then pull right off.
  7. Acer X191 monitor Display Assembly Replacement, Display Assembly: step 7, image 1 of 1
    • Remove the 2 pieces of yellow tape.
    • The bottom one have a thin sheet a metal on the underside which you need to take off too, if it does not come off with the tape.
  8. Acer X191 monitor Display Assembly Replacement, Button board: step 8, image 1 of 3 Acer X191 monitor Display Assembly Replacement, Button board: step 8, image 2 of 3 Acer X191 monitor Display Assembly Replacement, Button board: step 8, image 3 of 3
    • The button board is secured to the front frame by 2 plastic locking mechanisms.
    • To remove, insert a Flathead screwdriver into the gap to push the locking mechanism back a little, while pulling up on the board.
    • I found it easier to do one side at a time.
  9. Acer X191 monitor Display Assembly Replacement: step 9, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 9, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 9, image 3 of 3
    • Remove the bundled cable connector that is going to the top of the monitor. Grab the black tape that holds all the individual wires together, and pull gently.
    • Be careful to pull evenly on all the wires. You can do this by pulling strait out and not at an angle. Jiggling a little bit can help, but be careful.
  10. Acer X191 monitor Display Assembly Replacement: step 10, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 10, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 10, image 3 of 3
    • Remove the bottom foil tape from the back of the LCD.
    • Be sure to keep it. It helps dissipate static to the ground while the screen is in use. I recommend leaving the side of the tape that is sticking to the shield, where it is.
  11. Acer X191 monitor Display Assembly Replacement: step 11, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 11, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 11, image 3 of 3
    • Remove the remaining 2 pieces of foil tape from the back of the LCD.
    • Keep the pieces of foil tape. They help dissipate static to the ground while the monitor is being used. I recommend leaving on side stuck on the shield.
  12. Acer X191 monitor Display Assembly Replacement: step 12, image 1 of 1
    • Remove the 4 connectors that bring power from the powerboard to the LCD.
    • The connectors have a plastic locking tab on them, and the available space make them very difficult to pull out.
    • Next step shows one way to remove them without too much trouble.
  13. Acer X191 monitor Display Assembly Replacement, Removing the power cable connectors: step 13, image 1 of 3 Acer X191 monitor Display Assembly Replacement, Removing the power cable connectors: step 13, image 2 of 3 Acer X191 monitor Display Assembly Replacement, Removing the power cable connectors: step 13, image 3 of 3
    • Insert a Flathead screwdriver into the holes on the top of the shield. Lodge the tip between the socket and the connector and slowly push the connector out of it's socket.
    • Be very careful that you are NOT pushing on the socket itself, but the connector, ideally on the locking tab.
  14. Acer X191 monitor Display Assembly Replacement: step 14, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 14, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 14, image 3 of 3
    • Use a Phillips #1 to remove the 4x 8.5mm screws that are securing the shield to the display assembly.
    • Pull the shield up carefully.
    • The power board and logic board are inside the shield.
Sam
920 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 149
