Acrylic Nail Tip Replacement
  1. Acrylic Nail Tip Replacement, Acrylic Nail Tip: step 1, image 1 of 1
    • File the nail in a back-and-forth motion with the nail file on the accessible part of the natural nail until it is no longer smooth.
    • Try not to file the acrylic nail that is is still attached to your natural nail, as it will not fit the part that broke.
  2. Acrylic Nail Tip Replacement: step 2, image 1 of 1
    • Carefully place a drop of nail glue on the natural nail and let the glue sit for about 5 seconds.
    • Do not use more than 1-2 drops of nail glue.
  3. Acrylic Nail Tip Replacement: step 3, image 1 of 2 Acrylic Nail Tip Replacement: step 3, image 2 of 2
    • Place a nail tip in its original position and hold it in place for about 20 seconds, or until it is fully dry.
  4. Acrylic Nail Tip Replacement: step 4, image 1 of 2 Acrylic Nail Tip Replacement: step 4, image 2 of 2
    • Pour 30 milliliters of monomer in a small glass bowl.
    • Liquid nail monomer has a strong odor and is highly flammable.
    • Do not reuse the glass bowl for any food products because of possible chemical residue.
  5. Acrylic Nail Tip Replacement: step 5, image 1 of 3 Acrylic Nail Tip Replacement: step 5, image 2 of 3 Acrylic Nail Tip Replacement: step 5, image 3 of 3
    • Dip the brush in the monomer and lightly tap it on the paper towel to remove the excess.
  6. Acrylic Nail Tip Replacement: step 6, image 1 of 2 Acrylic Nail Tip Replacement: step 6, image 2 of 2
    • Place the tip of the brush in clear acrylic powder at about an 80-degree angle; collect it on one side of the brush.
  7. Acrylic Nail Tip Replacement: step 7, image 1 of 3 Acrylic Nail Tip Replacement: step 7, image 2 of 3 Acrylic Nail Tip Replacement: step 7, image 3 of 3
    • Apply the acrylic powder to the nail, and in a dabbing, downward motion, smooth the acrylic over the nail from top to bottom.
  8. Acrylic Nail Tip Replacement: step 8, image 1 of 1
    • Place the nail under the UV/LED lamp until hard and firm.
  9. Acrylic Nail Tip Replacement: step 9, image 1 of 3 Acrylic Nail Tip Replacement: step 9, image 2 of 3 Acrylic Nail Tip Replacement: step 9, image 3 of 3
    • Use a nail drill to file the nail to achieve an even acrylic coat by drilling in a side-to-side motion, working your way from top to bottom.
    • Use a speed of 7-9 on the nail drill.
    • If you do not have a nail drill, you can also use a nail file.
  10. Acrylic Nail Tip Replacement: step 10, image 1 of 3 Acrylic Nail Tip Replacement: step 10, image 2 of 3 Acrylic Nail Tip Replacement: step 10, image 3 of 3
    • Buff the nail until it is smooth, and use a paper towel to wipe off excess powder.
  11. Acrylic Nail Tip Replacement: step 11, image 1 of 3 Acrylic Nail Tip Replacement: step 11, image 2 of 3 Acrylic Nail Tip Replacement: step 11, image 3 of 3
    • Optional: coat the nail with clear polish.
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 30
All Time: 573
