Adjust Nintendo DS picture
  1. Adjust Nintendo DS picture, Adjust Nintendo DS picture: step 1, image 1 of 1
    • First check if the DS has image flickering. It is best to do this with a still image, such as the boot screen.
    • But make sure the backlight is on.
  2. Adjust Nintendo DS picture: step 2, image 1 of 2 Adjust Nintendo DS picture: step 2, image 2 of 2
    • Loosen the Phillips #00 screw on the battery compartment
    • remove the cover
  3. Adjust Nintendo DS picture: step 3, image 1 of 1
    • in these two openings are potentiometers responsible for the image.
    • Above is for the Upper LCD
    • Below for the Lower LCD
    • It's best to check both of them out.
    • Now you can turn on the console and make sure the backlight is on.
  4. Adjust Nintendo DS picture: step 5, image 1 of 1
    • Then you can turn left and right with the Phillips #00 screwdriver to adjust the picture.
    • But always take a look at the screens to get a good picture
    • It is also important not to turn too fast and not too far. The trick is to do this slowly and gently.
  5. Adjust Nintendo DS picture: step 6, image 1 of 1
    • If everything fits and the LCD screens display the picture well, you can close the battery door.
Close the battery compartment with the battery inside
Special thanks to these translators:
de en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Patrick Stork
353 Reputation
1 Guide authored
2 Comments
obrigado exelente
Andre Miranda - Reply
BOA NOITE
Gostaria de saber se as telas superior e inferior sao iguais??
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 72
All Time: 2,156
