Adjusting the front bonnet
  1. Adjusting the front bonnet, Locate the closing mechanism on the bonnet: step 1, image 1 of 1
    • Open the bonnet from the inside of the car (use the lever in the glove-box) and raise the bonnet completely open.
    • The 13mm screw used to adjust the closing mechanism of the bonnet. This is the one that probably needs adjustment
    • Screws which secure the mechanism to the bonnet
    • Spring which raises the bonnet slightly so that it can be further opened by hand
  2. Adjusting the front bonnet, Adjust closing mechanism using the screw: step 2, image 1 of 1
    • Use the 13mm Wrench to screw/unscrew the bonnet closing mechanism so that it gets adjusted. Usually it needs unscrewing a little so that it reaches the closing mechanism on the car.
    • The missing black paint on the screw indicates how much this bonnet closing mechanism needed adjustment
    • After adjusting, if unscrewing was needed and the closing mechanism screw shows unpainted parts it would be wise to spray-paint the area to protect from corrosion/rust in the future.
After adjustment the front bonnet should fully close easily when lowering.
3 other people completed this guide.
Dan Mihai Ile
186 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 62
All Time: 5,271
