Afterglow Wireless PS3 Controller Button Replacement
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: step 1, image 1 of 2 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: step 1, image 2 of 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: step 2, image 1 of 2 Afterglow Wireless PS3 Controller Button Replacement, Button: step 2, image 2 of 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Button Replacement: step 3, image 1 of 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Button Replacement: step 4, image 1 of 2 Afterglow Wireless PS3 Controller Button Replacement: step 4, image 2 of 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
  5. Afterglow Wireless PS3 Controller Button Replacement: step 5, image 1 of 2 Afterglow Wireless PS3 Controller Button Replacement: step 5, image 2 of 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Button Replacement: step 6, image 1 of 2 Afterglow Wireless PS3 Controller Button Replacement: step 6, image 2 of 2
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
  7. Afterglow Wireless PS3 Controller Button Replacement: step 7, image 1 of 2 Afterglow Wireless PS3 Controller Button Replacement: step 7, image 2 of 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  8. Afterglow Wireless PS3 Controller Button Replacement: step 8, image 1 of 3 Afterglow Wireless PS3 Controller Button Replacement: step 8, image 2 of 3 Afterglow Wireless PS3 Controller Button Replacement: step 8, image 3 of 3
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
3 other people completed this guide.
Aj Coello
1,038 Reputation
6 Guides authored
USF Tampa, Team S19-G5, Hoffman Spring 2017 Member of USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 91
All Time: 2,009
