Afterglow Wireless PS3 Controller Motherboard Replacement
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: step 1, image 1 of 2 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: step 2, image 1 of 1
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: step 3, image 1 of 2 Afterglow Wireless PS3 Controller Motherboard Replacement: step 3, image 2 of 2
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: step 4, image 1 of 2 Afterglow Wireless PS3 Controller Motherboard Replacement: step 4, image 2 of 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: step 5, image 1 of 2 Afterglow Wireless PS3 Controller Motherboard Replacement: step 5, image 2 of 2
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: step 6, image 1 of 2 Afterglow Wireless PS3 Controller Motherboard Replacement: step 6, image 2 of 2
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
Natalie Cox
207 Reputation
2 Guides authored
USF Tampa, Team S19-G5, Hoffman Spring 2017 Member of USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 38
All Time: 1,650
