Afterglow Wireless PS3 Controller Vibration Motor Replacement
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: step 1, image 1 of 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: step 1, image 2 of 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: step 2, image 1 of 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: step 2, image 2 of 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 3, image 1 of 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 4, image 1 of 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 4, image 2 of 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 4, image 3 of 3
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 5, image 1 of 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 5, image 2 of 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 6, image 1 of 1
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
Natalie Cox
207 Reputation
2 Guides authored
USF Tampa, Team S19-G5, Hoffman Spring 2017 Member of USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 23
All Time: 992
