Aiper Seagull Pro: Button bearing replacement
  1. Aiper Seagull Pro: Button bearing replacement, Remove the trash bin: step 1, image 1 of 2 Aiper Seagull Pro: Button bearing replacement, Remove the trash bin: step 1, image 2 of 2
    • Start by removing the trash bin from the robot.
  2. Aiper Seagull Pro: Button bearing replacement, Wheels: step 2, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Wheels: step 2, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Wheels: step 2, image 3 of 3
    • Put it on its side, then pry off the black plastic cap from the wheels.
    • Should be able to do this with your hand, but you could use a flathead screwdriver for some extra leverage.
    • Once the cap is removed, remove the screw.
    • Then remove the wheels.
  3. Aiper Seagull Pro: Button bearing replacement, Cover and middle cog: step 3, image 1 of 2 Aiper Seagull Pro: Button bearing replacement, Cover and middle cog: step 3, image 2 of 2
    • Remove the screws, then remove the plastic cover.
    • Remove the screw from the middle cog, then remove the cog.
  4. Aiper Seagull Pro: Button bearing replacement, Chassis screws: step 4, image 1 of 2 Aiper Seagull Pro: Button bearing replacement, Chassis screws: step 4, image 2 of 2
    • Remove the screws holding the chassis together.
    • I recommend a looong PH2 screwdriver for this task.
  5. Aiper Seagull Pro: Button bearing replacement, Other side's wheels: step 5, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Other side's wheels: step 5, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Other side's wheels: step 5, image 3 of 3
    • Flip it over and remove the wheels.
    • Then remove the side cover screws.
  6. Aiper Seagull Pro: Button bearing replacement, Other side's side cover and chassis screws: step 6, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Other side's side cover and chassis screws: step 6, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Other side's side cover and chassis screws: step 6, image 3 of 3
    • Make sure to open the charging port cover, so that it doesn't stop you from remove the side cover.
    • Remove the side cover and the middle cog.
    • Remove the 2 screws holding the chassis together.
  7. Aiper Seagull Pro: Button bearing replacement, Brush assembly driver cog: step 7, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Brush assembly driver cog: step 7, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Brush assembly driver cog: step 7, image 3 of 3
    • Remove the screw holding the side cog in place.
    • Use some leverage to remove the cog. It usually gets stuck in place due to limescale buildup.
    • Flip it on its back.
  8. Aiper Seagull Pro: Button bearing replacement, Brushes: step 8, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Brushes: step 8, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Brushes: step 8, image 3 of 3
    • Use 2x 7mm wrenches to loosen the bolts on the rod going through the front brushes.
    • Remove the rod.
    • Do not lose the washers. One is on each side.
    • On the side that you removed the other cog, remove the now removable cog.
  9. Aiper Seagull Pro: Button bearing replacement, Chassis: step 9, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Chassis: step 9, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Chassis: step 9, image 3 of 3
    • Remove the brushes by tilting them up on one side, then pulling them off.
    • If this is too difficult or the brushes are too tight due to wear, remove the 2 cogs on the other side and the brushes should just fall off.
    • Remove the 2 screws that were covered by the brushes.
    • Remove the top half of the chassis.
  10. Aiper Seagull Pro: Button bearing replacement, Ball bearing: step 10, image 1 of 3 Aiper Seagull Pro: Button bearing replacement, Ball bearing: step 10, image 2 of 3 Aiper Seagull Pro: Button bearing replacement, Ball bearing: step 10, image 3 of 3
    • Remove the 4 screws, then remove the button assembly.
    • Remove the ball bearing.
    • Either thoroughly clean it or replace it.
2 other people completed this guide.
DegenFixer
5,301 Reputation
24 Guides authored
1 Guide Comment
Hello,
By myself, i havn't seen the 2 screws hidden by the main large cog to remove the chassis top. Thanks for your clear explanations.
My problem is the power charge connector, corroded by the salted water (4g/L), since somebody forgot to re-install the cap of the plug. Further more, this somedy connected the charger after sweeping the pool. Result : Male and female connectors corroded... and no more electrical link. I correct with an ultrasonic bath, F2 fluid, (old) toothbrush and small grain abrasive paper.
Care, the connector dimensions are rare and almost impossible to find, or else much too expensive, it seems to be 6,5mm outer, and 3,4mm center pin. This exists, but very difficult to find. I'll probably change the couple by a true waterproof connection device..
Hope this helps ...
Flougartik 46 - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 1,033
