Air Blasters Tek Six Barrel Replacement
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: step 1, image 1 of 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: step 1, image 2 of 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: step 1, image 3 of 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: step 2, image 1 of 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: step 2, image 2 of 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: step 2, image 3 of 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: step 3, image 1 of 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: step 3, image 2 of 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: step 3, image 3 of 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: step 4, image 1 of 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: step 4, image 2 of 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: step 4, image 3 of 3
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: step 5, image 1 of 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: step 5, image 2 of 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: step 5, image 3 of 3
    • Lift the barrel, pulling it out from under the black trigger catch
Joshua Taylor
118 Reputation
1 Guide authored
USF Tampa, Team 3-1, Brown Fall 2014 Member of USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Members
5 Guides authored
One Comment
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 444
