Air Blasters Tek Six Trigger Replacement
  1. Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: step 1, image 1 of 3 Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: step 1, image 2 of 3 Air Blasters Tek Six Trigger Replacement, Remove screw of the grey slider: step 1, image 3 of 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Trigger Replacement, Remove screws in main body: step 2, image 1 of 3 Air Blasters Tek Six Trigger Replacement, Remove screws in main body: step 2, image 2 of 3 Air Blasters Tek Six Trigger Replacement, Remove screws in main body: step 2, image 3 of 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Trigger Replacement, Take the main body apart: step 3, image 1 of 3 Air Blasters Tek Six Trigger Replacement, Take the main body apart: step 3, image 2 of 3 Air Blasters Tek Six Trigger Replacement, Take the main body apart: step 3, image 3 of 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Trigger Replacement, Remove the trigger: step 4, image 1 of 3 Air Blasters Tek Six Trigger Replacement, Remove the trigger: step 4, image 2 of 3 Air Blasters Tek Six Trigger Replacement, Remove the trigger: step 4, image 3 of 3
    • Grab the orange trigger and without misplacing the other parts of the blaster, remove the trigger.
2 other people completed this guide.
Alfredo Antolinez
347 Reputation
3 Guides authored
USF Tampa, Team 3-1, Brown Fall 2014 Member of USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 672
