Air Hog Smash Bots Controller Motherboard Replacement
  1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: step 1, image 1 of 2 Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: step 1, image 2 of 2
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Controller Motherboard Replacement: step 2, image 1 of 1
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Controller Motherboard Replacement: step 3, image 1 of 1
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Controller Motherboard Replacement: step 4, image 1 of 2 Air Hog Smash Bots Controller Motherboard Replacement: step 4, image 2 of 2
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Controller Motherboard Replacement: step 5, image 1 of 2 Air Hog Smash Bots Controller Motherboard Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: step 6, image 1 of 2 Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: step 6, image 2 of 2
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
Brittany Frecker
542 Reputation
4 Guides authored
IUPUI, Team 1-1, Baechle Spring 2016 Member of IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Members
14 Guides authored
One Comment
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 172
