AirPods Pro 2nd Generation Ear Tips Replacement
Video Overview
  1. AirPods Pro 2nd Generation Ear Tips Replacement, Flip silicone earbud tip out: step 1, image 1 of 1
    • Carefully pop out (or flip out) the ear tip of your AirPods Pro, prior to trying to remove them. This will ensure that you avoid accidentally ripping the delicate end of the AirPod Pro ear tip.
  2. AirPods Pro 2nd Generation Ear Tips Replacement, Pull off ear tip from the base: step 2, image 1 of 1
    • Don't rip the ear tip off using the end. Make sure you gently, but firmly pull the AirPod Pro ear tip from the earbud close to where it connects. It takes a little force, so don't be afraid to pull it out.
  3. AirPods Pro 2nd Generation Ear Tips Replacement, Snap on new ear tips: step 3, image 1 of 1
    • Align the new ear tip so that either the "L" or the "R" align with the black stripe on the AirPods Pro earbuds.
    • Snap in the new ear tip. (You should hear it snap.)
    • Fold back the silicon ear tip to the normal position
    • Don't misplace the AirPods Pro ear tips you just took out. You never know when you'll need them in a pinch.
  4. AirPods Pro 2nd Generation Ear Tips Replacement, Ear Tip Fit Test: step 4, image 1 of 1
    • Try Apple's ear tip fit test to see if your buds fit correctly and if they work well with your ears. If it tells you to change it, try a smaller or bigger one out by repeating all steps over.
9 other people completed this guide.
tayola
9,874 Reputation
44 Guides authored
0 Guide Comments
Past 24 Hours: 70
Past 7 Days: 371
Past 30 Days: 1,653
All Time: 79,240
