AirPort Time Capsule A1409 HDD Replacement
David Medrano
David Medrano and 2 other contributors
Last updated on September 28, 2024
No estimate
Moderate
Community-Contributed Guide
  1. AirPort Time Capsule A1409 HDD Replacement, Hard Disk Drive: step 1, image 1 of 3 AirPort Time Capsule A1409 HDD Replacement, Hard Disk Drive: step 1, image 2 of 3 AirPort Time Capsule A1409 HDD Replacement, Hard Disk Drive: step 1, image 3 of 3
    • Put the unit upside down and take off the rubber bottom cover. It is better to start at a corner.
    • Rubber becomes brittle as it ages. Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    The rubber tears real easy with age so carefully work your way inwards from each corner.
    AndreasT - Reply
    Just happen to me :/
    Ben Capehart -
  2. AirPort Time Capsule A1409 HDD Replacement: step 2, image 1 of 3 AirPort Time Capsule A1409 HDD Replacement: step 2, image 2 of 3 AirPort Time Capsule A1409 HDD Replacement: step 2, image 3 of 3
    • Remove the # 10 Phillips # 00 screws that hold the Time Capsule's lower metal bracket.
    • Open to the left leaving the network connectors on that side. Do not open it fully to avoid breaking the fan cable.
    thanks for doing this guide.
    1. remove hash sign (#) before the 10. “Remove the 10 Phillips...
    2. second bullet - “Do not open all the way to avoid…
    Brian McNiff - Reply
    I agree!
    Good Job!
    Ben Capehart -
  3. AirPort Time Capsule A1409 HDD Replacement: step 3, image 1 of 2 AirPort Time Capsule A1409 HDD Replacement: step 3, image 2 of 2
    • With the tip of a spudger carefully remove the fan connector then remove the metal bottom cover.
  4. AirPort Time Capsule A1409 HDD Replacement: step 4, image 1 of 3 AirPort Time Capsule A1409 HDD Replacement: step 4, image 2 of 3 AirPort Time Capsule A1409 HDD Replacement: step 4, image 3 of 3
    • Find the temperature sensor on the surface of the hard disk.
    • Carefully remove the tape covering the temperature sensor.
  5. AirPort Time Capsule A1409 HDD Replacement: step 5, image 1 of 2 AirPort Time Capsule A1409 HDD Replacement: step 5, image 2 of 2
    • Remove the clip that holds the temperature sensor and remove both.
  6. AirPort Time Capsule A1409 HDD Replacement: step 6, image 1 of 2 AirPort Time Capsule A1409 HDD Replacement: step 6, image 2 of 2
    • Lift the hard drive a bit without pulling too hard to not cause damage to the power and data connectors of the hard disk. Removing the power connector from the hard drive
    • Remove the data connector from the hard disk.
  7. AirPort Time Capsule A1409 HDD Replacement: step 7, image 1 of 2 AirPort Time Capsule A1409 HDD Replacement: step 7, image 2 of 2
    • Once we have the disc out of the Time Capsule, we remove the 4 Phillips head # 00 pillars and place them in the new unit.
    A #1 Philips works a lot better on these
    Heath Kehoe - Reply
    Not gonna lie, I used a eye glasses repair kit screwdriver.
    kilereeds -
    Wow worked perfect! Thanks! But funny thing is I wanted to remove the hard drive to upgrade my Windows 11 Home PC and I just used dos kill disc to wipe it to 0’s
    kilereeds - Reply
    Hello there, is this SATA II or SATA III HDD?
    Tomas Fiala - Reply
    the #00 philips wouldn't turn the 4 screws in the hard drive (step 7) and I ran the risk of stripping either the head of the screws or the screwdriver itself, but the work around was use a pair of pliers to turn the screws from the outside first, loosening them enough you can use the screw driver. Torx screws would be a lot better here
    Matt Cowan - Reply
To reassemble your gadget, follow these instructions backward.
47 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
David Medrano
1,705 Reputation
1 Guide authored
Tecnico Center Teatinos, S.L. Member of Tecnico Center Teatinos, S.L.
Business
1 Member
4 Guides authored
15 Comments
I replaced a dead drive in about 30 mins following these instructions. The steps are clear, straight forward and the photos were extremely helpful. Many thanks as I now have a renovated AirPort Time Capsule.
Peter Long - Reply
I just replaced the 2 TB WDC Green with a WD Red Pro 4 TB with this guide in less than 30 min. Except for the fan cable it was a cake walk.
Alex Senger - Reply
Successfully upgraded my A1409 to a Western Digital - WD100PURZ - 5400 RPM Class SATA 6 Gb/s 256MB Cache 3.5. There are two additional steps: (a), there is a rubber strip around the original drive that reduces noise and protects the drive, gently remove from the original drive and place on the new drive; (b) once the rubber strip is on the drive, it is hard to get into place, angle the drive towards the connector side, and press in.
Brunob00 - Reply
12 TB WD RED (inbuilt version WD120EMAZ) just confirmed for 1409 (G4 version).
you are welcome
AD G - Reply
Hola. Reemplacé el disco con toda facilidad pero, desgraciadamente, la Utilidad AirPort no lo está reconociendo ni consigue borrarlo para activarlo. El HD nuevo es un WD Red de 10 TB. Si alguien puede ayudarme a resolver el problema, agradezco mucho.
I MM - Reply
Hi. Is it possible to upgrade this to an SSD?
Bobby Barbour - Reply
Yes, you could also use an SSD, just follow the same procedure.
Idrees -
How to Clone or Copy data to a new hard drive?
Ben Capehart - Reply
4 TB WD Green drive replacement. 30 minutes start to finish, backup just started after formatting the disk. DO NOT forget to format the disk first. Disk format can be done from within the Airport Utility. Don't forget to remember that password!
jay Snoke - Reply
It's not formatting the installed WD Red WD101EFAX which I've installed. Any help or suggestions?
Evgeny Kozlov - Reply
Take it out then Try formatting it on Mac and then re-install it and try formatting again.
Ben Capehart -
This was super helpful. I used the microwaveable ifixit gel opener to loosen the glue on the rubber pad. Starting from one side and wedging a metal pry tool underneath as I moved about 1-2 inches at a time, reheating every few inches. Worked perfectly, no rips or tears on the rubber.
I mounted an SSD with VHB tape left over from another project, it holds drive securely against the side of the drive mount.
During reassembly, the glue on the back is still tacky enough to hold the rubber on, but a few small pieces of VHB tape in the corners helped.
It’s actually useful again, and very handy for my legacy Macs. Thanks for posting this!
Daniel PCRR - Reply
Any guide / advice on the largest HDD that has been used, want to upgrade my 2Tb one... probably 4-8Tb
Anthony Clarke - Reply
Thank you for the guide. I have replaced faulty hard drive to the new one with no problems.
Artur Pędziwilk - Reply
Do you think an SSD could speed up the backup, or is it better to maintain an HDD with 5400 RPM or 7200 RPM? Is there a limit to the SATA buffer speed?
riccardo delfanti - Reply
Past 24 Hours: 8
Past 7 Days: 84
Past 30 Days: 534
All Time: 25,599
